1 - 3 of 3 Posts
i got my koolvue mirrors and my mirror bracketsfor my 01, and sounds stupid but this is my first ram, where do the brackets go excatly, pic would be awesome, thanks guys
you have to remove the door panel, and when you remove the old mirror. The bracket goes on the inside of the door where you pulled out the foam to get to the nuts for the mirror, put the bracket in the hole and put on new mirror, ur nuts will go against this bracket pulling the bracket tight against the door shell.
Hemi
Yep sandwich the door between the bracket (inside) and mirror (outside). :thumbsup:
1 - 3 of 3 Posts
