In my truck it locks out 5th and 6th (overdrive gears).When utilizing tow/haul without a trailer or load does it lock out 6th gear? Is there any benefit to driving this way?
So Tow/Haul Mode on your 2014 wont allow it to shift into 5th or 6th gear? Because thats what I read as locking out 5th and 6th. If thats the csae than 2010-2012 are not like that, I put mine in Tow/Haul everytime I drive with the Exhaust Brake on and I have all 6 gears.
When I put it manual gear mode by pressing the + on the shift lever without tow/haul active it shows 6 as my highest gear. When I activate tow/haul it shows 4th as my highest gear. I will double check this on my way to work tomorrow morning.In my truck it locks out 5th and 6th (overdrive gears).
In my truck it locks out 5th and 6th (overdrive gears).I just went out to the truck, and it looks like I'm wrong about it locking out 5th and 6th. It must have been me keeping it in 4th gear not tow/haul mode.
I turned ignition on pressed the - button on shifter and it showed 6th as highest gear, pressed tow/haul and still showed 6th as highest gear. So it looks like I made a mistake sorry about the confusion.
Correct! You definitely don't want to be lugging around when driving around ton. I'd much rather have the higher shift points and higher rpm's while city driving.Better for the transmission to run that way without hunting threw all the gears in city driving?
You beat me to this question as I'm wondering the same thing.Anybody ever figure out the difference in mpg driving around town vs no T/H mode.
Souldnt matter in either drive works the same in both for me. I would use tow/haul, and depending on how the truck acts with EB leave it off.I was wondering i run with EB on and the T/H on all the time and going to be plowing is it good to plow with the T/H on and EB on? And will it matter in 2wd or 4wd?
If going between 50-60MPH I would keep tow/haul off. I have found that it will stay in 5th until you get to about 60 then it will shift. Tow/haul is good in the city but it would be better if it would stay in the higher RPMs alittle more sometimes it shifts to quick for me.I decided to use the tow/haul mode going home from work, it did seem to have a little more pep and the engine brake seemed a little stronger than with the tow/haul turned off, I think I will run it that way for a while.
If you could disable ABS it will turn trac control off, it works off of ABS. There maybe a fuse to disable trac control but the government prob mandates that its computer controlled.Is there a way to force the truck to start with T/H engaged? And have the traction control off, and STAY off? I'm constantly pushing buttons in this silly truck!
