1 - 4 of 4 Posts
i recently pulled my grandparents' 30 foot 5th wheel (converted to gooseneck). i was pulling up some hills around 55mph and was running in tow/haul in my 06 cummins. it was never wanting to shift out of overdrive. is this normal? or do you automatically need to keep it in "o/d off"? my dad has always had a powerstroke and i've pulled more with it than my cummins and it downshifts alot, but that v-engine should just based on torque/power curves. i know that cummins makes so much of it's power down low rpms, but does this sound ok?
Sounds normal to me. Power on a stocker is around the 1500 rpm mark, so that's about right for 55mph. Typically, i don't see the trani downshift til I get down around the 47mph mark or so unless i power into it, but if your holding the pedal steady and letting it work at 55, you're good to go.
The two differences that i see using the tow/haul mode is that it shifts into 3 and straight to lockup, then 4th and lockup somewhere around 50 if you're being nice to it. I wouldn't be too concerned, but might not be a bad idea to throw some gauges on if you think that trani temp or rear end temp is going to be a problem. That's the best way to tell what's going on.
Banned
Powerjokes like to shift...a LOT. Cummins has so much more torque that it rarely needs to shift. Like stated, it sounds perfectly normal.
Ya, I couldn't believe it the fist time we pulled our 5er through Penn. That thing refused to downshift (almost) I was thoroughly impressed with it. Now if we could get 30MPG, I would REALLY BE IMPRESSED :lol3::lol3:
John :T:
1 - 4 of 4 Posts
