Some of this has been covered I know after doing searches, but this is my new experiences. I am now hauling commercially with a 40' flatbed and my MegaCab. The truck is a 2012 with an auto and 3.73 gears with Max Tow. I towed several loads of my dedicated run with the 3.73 weight combined is 25,300 with 3/4 tank of fuel. i was getting 8-8.7 mpg loaded depending on speed and 12 empty avg.
i recently had a 4.10 gear put in the rear end, thinking the truck was working too hard running too low an RPM. We pulled the front driveshaft as well. I am now seeing 7-7.8 mpg on average loaded and 11-11.2 empty (Empty = Empty with trailer)
Trailer is about 10k empty tandem duals with Electric / Hydraulic disc brakes.
Now seat of the pants says the truck likes the 4.10 gears better, but Milage says otherwise. Should I stick with the 4.10 and suffer the milage or switch it back to 3.73. I also had a 31K gross load that was low on the deck and got 10 loaded with the 3.73. My daily load is up in the wind creating a lot of turbulance. They are steel racks. run 500 miles (250 miles each way) per day, loaded and back empty. I dont look for back loads as the dedicated route pays better to just get back to releoad each day.
Thoughts or suggestions please
