1 - 13 of 13 Posts
· Cummins Crazy
ok guys I had thread awhile ago but I still didnt rest my mind on the following...I can turn my smarty way up #5,#7 and the truck won't spin the tires...I've noticed if the truck is sitting still and my foot calls for lots of fuel :) the truck wont keep building boost it just defuels...I cant even spin the tires standing still and flooring it...all my other vehicles make big power and have no problems of this sort, so this has been bothering me for the past year of my trucks life....does my truck have a problem or what...runs fine other then the defueling when sitting still
· Cummins Crazy
Discussion Starter · #2 ·
to top it of my buddy has similar truck but a 2005...his truck will roast the tires without programmer
Are you getting the overboost code. if you are you are right in thinking its defueling. so ive been told. in which case i believe a boost fooler should do the trick. i think.
· Cummins Crazy
no codes ever....I always figured with the tq management it should do it...but with the smarty and the tqm pretty well all but turned off it should boost up more....the smarty is supposed to do boost fooling I've been told
Something has been done to the 05 cuz they would not spin the tires stock either.
If you have not changed out the TC your just driving thru the fluid coupling and hitting the defuel point with no wheel speed. Programmers do not reset that parameter.
Get a tighter TC and you will see the differences.
:agree2:the transmission is your problem.
I couldnt hardly turn them over either without a little brake action. Just got my new tranny in last week and now I can litterally roast the tires all through first gear. i need new tires now : (
Hmm.. mine can spin them up to about 40mph with no brake... that is if i go past torque management 1... and I am not doing that right now because the trannys life is going fast.. :(
· Cummins Crazy
Discussion Starter · #11 ·
yeah figured the trans was junk...i was just worried there might be another problem...trans will be an early winter job...thanks to everyone for your input
same here!
1 - 13 of 13 Posts
