1 - 4 of 4 Posts
I have a 2005 dodge ram diesel 3500 with a 48re. When im in drive at a set of light the torque does not stall, it wants to pull through the brakes. Any ideas? It just started acting up on me, might be a temp issue (its freaking cold out here).
To me that sounds like a good thing. You know it's multipling the engines torque. But it's probably from the outside temps. Does it do this after a extended drive? You might just have to push the brakes a little harder.
no its not a good thing. It s at the point were it walks there the brakes. any ideas what it is?
Have you changed the oil? Might also have a problem with your brakes. It shouldn't be able to go through them even in first. Not like a powershift in a tractor. Not that big of a reduced gear ratio.
1 - 4 of 4 Posts
