i have a 00 2500 i have been experiancing a problem the last few days where after it goes in the lockup it will erratically pop in and out unless i hit the lock up switch just wondering if anyone suspects that i have a torque converter on the way up or just the lockup solenoid problems the trans was rebuilt around 80k ago has bd valve body stock converter. I am planning on going with a new converter should i go with a triple disk right away or should i stick with a single billet mods are in sig will be upgrading injectors in the next few weeks thanks for your help guys!!!
Have you changed fluid lately???
Check and clean your grounds on batteries. Thats one possible thing that will cause that
Try wrapping the tan alternator wire with aluminum foil and electrical tape. The Alt. sends out a lot of electrical "noise" which confuses the trans computer. This cause your tc to lock and unlock. Cheapest fix I ever did.
:agree2:..
