This thread basically follows my transmission build. Check it out!
READ THE BOTTOM
Jan 30, 2016: My 47re started going south so I took it to my local trans builder and I got quoted @ $2,400. He said it can hold 600-700 horsepower.
He said it would have a wider 2nd gear band
recon double disc converter
Borg Warner/Red Eagles clutches/gears
not sure about the valve body or anything else...
I asked about a billet input shaft and he said he does not see it necessary because he hasn't seen one break. (Maybe he means with his builds with double disks vs triples)
I don't know... give me your thoughts. Is this too good to be true or what? The trans is getting built as we speak so hopefully it is solid.:hehe::blues:
2/4/16: EDIT: THE TRANSMISSION IS DONE I AM PICKING IT UP TOMORROW. THE TOTAL COMES OUT TO $2,782. DOES IT STILL SEEM TOO GOOD TO BE TRUE? GIVE ME YOUR THOUGHTS MY BROTHERS
2/5/16: Picked the truck up, he gave me a run down of the parts he used in the build, showed me some of the old components and such, and then charged me (obviously). Here's the build sheet...
1. Recon Torque Converter HD Triple Disc
2. Master Kit
3. 2 Governor Solenoids
4. New wire harness
5. Bushing Kit
6. Planetary (front)
7. Filter + pan gasket
8. 2nd gear band
9. 14 quarts atf synthetic oil
10. Forward Drum
11. Red eagle clutch set
12. 2/26/16: Accumulator piston & Trans-go shift kit
He additionally told me to come back every 20,000-30,000 miles for a service depending on how I drive. I asked about an aftermarket transmission cooler; he said that mine is just fine. I asked about a deep pan, he said that it would be beneficial.
So boom, I'm on my way! Driving down the road slow initially until the truck warmed up. Gave it a test romp, shifts nice and positive, no slipping, perfect. Mind you the truck is still stock (215hp, 420hp tq)
Here are a few pictures of old garbage he showed me and a happy me:
Now I have some questions for you guys!
1. how much power do you think this setup can hold and for how long? (Yes, I am aware that with a triple you should have a billet input shaft. My builder said he hasn't seen many break in the automatics.
2. Does his 600-700 hp quote seem plausible?
3. Finally, is it too good to be true?
Does it make sense to spend 6 grand on suncoast, dtt, revmax, etc. or does it make sense to go to your friendly neighborhood builder?
Okay update on the build: 2/13/16
1. Going uphills in od let's say 1500rpm or so I feel like I get some torque converter shudder. Everything I search indicates that the torque converter is on the way out. This is unlikely because it is only 6 days old.
2.While going 40-45 I feel like I'm getting some hunting (downshift-upshift 3-4 3-4) Not a lot but from time to time. I already have the apps noise isolater installed.
3. When I put the vehicle into drive you can really feel it. (not grinding or anything but it's hard)
4. Being that I have a stock vb and a triple disc should I get a dtt valve body with the gm solenoids
Update 2/13/16: 1. throwing some 100 sticks in and then Saving for goerend or revmax performance valve body
Update 2/15/16: Took it back to the builder. Getting a trans-go shift kit and some other goodies installed. (should fix/fine tune the minor issues)
Update 2/26/16: Trans-go shift kit is installed and I also got an accumulator piston put in or something like that. Feels great. 100% Stock body will remain in the vehicle as long as the trans-go continues to do its job
Have a good day
Update 2/24/17: TRANS NOW HAS 25K MILES, JUST RAN INTO PROBLEMS WITH IT. NOT DOWNSHIFTING PROPERLY, FEELS LIKE IT'S STUCK IN 3RD GEAR. Slips when cold, sometimes won't shift at all unless I back out of the throttle. He is going to do a fluid change and filter and he told me to leave him a list of things that is wrong with it and he will look at everything. If it's my torque converter it is under manufacturer warranty for another 11k miles, if it's my clutches (which I think is likely) I might have to put some money down.
For those of you who do not know, he gave me a one year warranty which expired 2/5/17. Luckilly he is being very nice and working with me to get it back up and running to 100%.
I had him lower the pressure about 3 months ago because I felt as if it was shifting harsh. I wish I did not do that because firm shifts are just the nature of a triple disc/built tranny.
Truck is getting worked on tuesday 2/28
Will keep you guys updated.
READ THE BOTTOM
2. Master Kit
4. New wire harness
5. Bushing Kit
8. 2nd gear band
10. Forward Drum
Have a good day
