I run mine on TNT 9 w/ all stock fuel system and I hold 25kpsi of rail pressure at full boogie
A stock fuel system will not be able to keep up with the fueling demands of the TNT and you will more than likely starve your Cp3 causing even more problems.. The TNT software from smarty was designed for moddified trucks and with a stock engine you will not be able to take full advantage of it.. The TNT can be downloaded from Mads Electronics - Smarty - CaTCHER - Dodge Tuning - Homewill i be able to run my tnt on my stock fuel system with no lift pump??? also do u get tnt from mads website and download it to the programmer
Well I guess I'm wrong..:confused013:I run mine on TNT 9 w/ all stock fuel system and I hold 25kpsi of rail pressure at full boogie
x2. All stock fuel system, no fuel press. gauge, for that matter the rail press. gauge suddenly stopped working :doh:I purchased an AirDog 150 and a Hellmann sump while my tranny was being built because I knew I would be running the TNT software. I got the truck back and loaded up the TNT just to see what it would do. Ran great!
I put the header, turbo, and gauges on and it was holding great pressure. even on level 9!!
now, would I benefit in the midrange with the fuel system and a CP3 upgrade? I'm sure I would. But for the time being, I'm quite pleased with the performance. No, I do not have a fuel pressure gauge between the lift pump and the CP3. (not sure I want to know!!! hahaha)
also, FWIW, my current fuel filter has at LEAST 20k miles on it that I know of! LOL
:ditto: Like I stated earlier..:thumbsup:cmon guys, you can run the tnt with a stock fuel system, but wont recieve anywhere near its full potential at all.
well, if you've got a stock fuel system, you'll receive more potential from the TNTR on 9 than with any of the other Smarty programs, so...cmon guys, you can run the tnt with a stock fuel system, but wont recieve anywhere near its full potential at all.
Its def. a more powerful software than just the standard revo just start on a lower setting and work your way up... I dont see a rail pressure gauge in your signature and if i were you i would invest in one..:thumbsup:All good info. I've been debating on downloading the tnt tune myself.
Yup you'll notice a difference just make sure you have the RP guage installed before you download the new software...Nope no rail pressure gauge yet but I will get one before I download the tnt. Thanks smoking5.9L. Pretty huge difference from revo to tnt is there ?
