1 - 20 of 21 Posts
What tire size looks good on stock height?
I like my 255/85r16's
really depends on what your looking for..
mopar1973man drives 265/75r16 in winter and 235/85r16 in the summer for the added mileage. (both of those sizes are near equal in circumference about .2" off)
I went with my choice just cause it was an even step between the two with a little bit more added circumference which seemed to have helped with fuel mileage although I cant give you an exact number on that.
On call 24/7
Dracozny, can you post some front and side pices of your truck with these 255's. I have been looking for a second gen 3/4 ton with these but havent had any luck. I like the way 285's look but have been thinking of going the 255 route becasue they are alot cheaper.
the only manufacturer for this size is cooper but you can usually find them rebranded like mine. check out the smaller tire shops in your area they usually can get you a better price.
On call 24/7
I run 17's on mine and have been thinking about the BFG mud tire in a 255/80/17 but just can make up my mind.
Did you end up getting the BFG 255/80/17's? Any thoughts (mileage, too skinny, snow, etc.)? Glad for any info and pictures would be great.
Mopar1973Man.Com
Roughly for every 4 pounds of rotational mass you lose you need 1 less HP to keep rolling.
265/75 R16 = 85 Pounds per tire = 340 pounds for all 4.
235/85 R16 = 62 Pounds per tire = 248 pounds for all 4.
340 - 248 = 92 Pounds Difference...
Rotational mass (total weight) and rolling resistance (face width) make a huge difference.
Reactions: redrocketoflove
Sasquatch
On my old '99 I noticed a big improvement when switching from 285/75/16 AT to 235/85/16 HT. Mileage increased, slight increase on the butt dyno and the truck performed a lot better in deep snow. The best part is that they don't throw as many rocks against the truck.
On call 24/7
No, I eneded up getting 305/70/17 nitto terra grapplers and other than the scrub on upper control arms at full lock, im completely satisfied.:thumbsup:
FRIENDS OF COAL
265/75/R16's look alright on a stock height... I believe they come from the factory with 235-245/75 tires...
One tons came with 215/85's IIRC, but I think your right on the 3/4 tons, Don.
FRIENDS OF COAL
Because when I first got mine it had 245/75/R16's on it... I always said Dodge Wheel Wells are just massive, I got 265/75 BFG Muds now but Im planning on going to a 285/75 or a 295/75 next. I am just hesitant about the 295's rubbing?
No prob. You could go up to 305's before you get close to rubbing. 315's might rub though.
I have 285/75/16 cooper S/T Maxx like em so far. They had pretty good reviews
Sent from my iPhone using Autoguide
Does anyone know the max tire size I can run without rubbing (full suspension travel, etc.) on a 1999 4X4 with 3rd gen. alloy wheels?
Dealers say the 285/70/17 (~33.1" diameter) may work.
Also looking at the 255/80/17 KM2's (~33.3" diameter) but dealer was skeptical about rubbing.
If anyone knows the tread width of the 255/80/17 KM2 I'd be glad to know. Have found specs from 7.1" to 7.9".
1 - 20 of 21 Posts
