Tire Size?
538 Views 6 Replies 5 Participants Last post by  grporter
I have a set of 17x9 rims with no tires and was wondering if I could fit 35x12.50x17 tires on my truck with just the leveling kit and no rubbing? Also I have 20x10 and what size tires can I fit on those with no rubbing? If you guys have pics post them up!!!!
"heard" that you can run 35's on your truck with just a levelling kit......No facts though.
35" tire is equivellent to about a 305/315 size metric.
I use this to determine true metric tire diameters and RPM, Speeds etc.
4LO.COM :: On-Line Gear/Tire Size Calculators
I have 305 tires on my 20's now and it had 315/70/16 on it when I bought it.
As long as you have more back-spacing than stockers the 17x9 will work. My old stockers with 285's rubbed on the control arms.
is 33.4" dia..... slightly under a 35 (which doesnt really measure 35") according to the link I posted.
Need the aspect ratio for the 20's to verify dia.?
Ive got 315/70/16's on mine. The only time they rub is on a tight turn, and they hit the control arms.... They look good.. but it doesnt sound good when they rub
go to the tire manufacturers website for the true size. i've looked up 37s on several sites ranging from 36-37, so even the metric or standard numbers won't tell you the real size!
