1 - 17 of 17 Posts
I think I've read most of the tire threads on forums, but I still habe doubts about tire choices. Some background: 2016 Ram 2500 HD Laramie with towing pkg, factory rear airbags, 285/60R20 tires. It's not a daily driver so have less than 30K miles. On the second set of tires, Continental TerrainContacts that can't be balanced. Road force balancing leaves the tires one 50 lbs off. And that's after 3 off 4 were warranty exchanged for v the sane reason. Bad manufacturing week -- all 6 bad tires were same week. Anyhow, getting ready to drive a few thousand miles in December towing a car on trailer so gotta get the Conti's off.
Much of the use is towing a 14,000 lb gooseneck dump trailer, half that fully loaded over curvy, hilly, paved roads. But-- the last stretch is usually through the yard, barnyard, or field. Seems to me it doesn't matter if 99% of the driving is on pavement if you can't go that last half mile.... In the future, we'll probably get a travel trailer, so one requirement is for good highway driving. But I also don't want to get stuck in soft (not muddy) yards. Get really close with the Conti's.
Can anyone suggest why I shouldn't go to 275/65R20? A little taller and narrower, but much more common than the stock 285s.
I'm torn between the Falken Wildpeak A/T3W and Michelin Agilis Crossclimate that came out in April this year. Both have the 3PMSF designation and the Crossclimate seem really well suited to our heavy trucks. But the Wildpeak seem less likely to leave me spinning wheels in yard. Anyone have the new Crossclimates yet?
Thanks for your insights!
From what I can tell, the Falkens, Cooper AT3 and the Goodyear Ultraterrrain may be your best bet.
The Cooper ST Maxx maybe better for what you are looking for in a tire. The 285/60/20 are available form many places, really no reason to deviate unless you have issues, like a manual trans then a 34" tire will help immensely. No idea on the Falkens but would not consider the michelen.
Thanks for the feedback RBros_JLR and cerberusiam. I forgot to mention that I live in a rural area that makes it challenging to get some tires. One of the primary local tire shops can get 285/60R20s in just two models! I'm really leaning towards the Falken Wildpeaks as the best compromise. I'd stick with the stock 285/60, though I'm very tempted to try the 295/60s. Thinking the ST Maxx's would be overkill considering the ratio of highway to offroad driving I do. I also have ample 'extraction vehicle's' available (two tractors and two track loaders).
Any thoughts on 285 vs 295?
Then the Cooper Discoverer ATP may be more what you want. That is what we are running on our dually, so far with about 10k miles no issues.
The tire height would be my concern with a 295, the correct tire is an inch taller and that might put you out of the sweet spot on your truck. Depend son what transmission and gear ratio you have.
Different size but I've get a set of the Falkens and have been well pleased. Good grip on and off road, good ride, tows well with my 31ft 5th wheel and little or no noise. Put them on at 55k and am at 110k with quite a bit of life left in them. Will probably well exceed the 65k treadlife warranty they have.
I like the ATP's, but they are exclusive to Discount Tires. Closest one to me is over 100 miles away. If I have them shipped, by the time I pay a tire shop for installation, they don't make sense. The only tires on the Cooper site that are listed for 285/60R20 are the AT3 XLT and the S/T MAXX. I have the 6 speed auto and 3.42 axle.
Considering I can get the Falken Wildpeak's for under $1200 out the door, that's probably the way I'll go.
You may want to check out the Toyo C/T, if they are available in the size you want.
But whatever you buy can be mail ordered, in many cases with free shipping, so don't worry about local availability.
If deep mud is the problem much of the year, get the widest faced tire 28030952 LT305/55R20 A/T3W if they will fit your rims , 1 inch wider that your present stock size. Floats across soft ground much better. A/T3W has good side mud lugs for grip in mud by side of tire when face lugs are full and won't clear due to grass/etc.
There are established maximum (and minimum) tire widths for a given rim size for a reason.
Handling goes out the window when going on the wide side, or over.
Besides, there's only so much flotation to be had with the contact pressure that results from some 2,500 lbs. of weight on a front tire.
Discussion Starter #12
Deep mud is rarely an issue as I can readily avoid driving off the driveway then. It's more the soft ground that's an issue. Should have taken some photos last week when I spun the rear tires moving the empty dump trailer through the yard. 4WD is an absolute necessity.
I looked at 305s, but then I'd have to go to load range F. Not many tires fit that bill, and they starry getting pricier.... I read somewhere that anything over 12" wide can be a problem on the 2500 trucks. Not positive about that, though.
Tire width is not a 2500 issue, it has to do with using the correct wheel width for the tire.
Then what those wider wheels do to bearings and steering geometry is another thing altogether.
The Falken 305 is an E rated tire. 9.5" rim width recommended.
What you got on the rig now for rim width?
Run 2 sets of tires, highway stocker size for your RV towning and the big Falkens for your soft ground hauling. Solves any potential yeararound RV handling towing problems and excessive front end wear from wide rims/tires.
Or go even wider Falken 28030125 LT325/60R20 for soft ground tires.
I run 2 sets on mine, highway all season for RV towing and a wide HD rock/mud grip for hunting and running in the mountains, mud logging roads, deep snow and rough ground. HD air wrench and you're all set.
Or get a dually for soft ground mud work towing. That trailer is probably sinking in drastically increasing tire drag. Then it's just grunt pulling power to the ground without sinking or digging in and ONLY duallys can produce that.
If the problem is traction only on slick grass or mud, then you need something like a HD lugged tire Falken Wildpeak MT01 Firestone Destination MT2 Cepek Extreme Country Nitto Trail Grappler M/T or Super Swampers for the maximum traction from single tire rearend
Interesting. My experience with duallies has been the exact opposite.
gotta have weight on the back end of a dually to make it dig in and grab on slick clay or grass on clay.
5,000 lbs over the rears is not too much. load some gravel in the box
1 - 17 of 17 Posts
