1 - 13 of 13 Posts
Ive done a ton of reading and what not and I just need to be told point blank.. Will the XD monsters 20x9 with 18mm offset fit on a stock truck. (With cooper zeon ltz LT275/65R20 34.21x11.27 is the measurements on the tire) . An how far will the 18mm stick out. I had xd revolvers 17x9 with a -12mm offset and loved that offset, just wanna get close to that same look. Filled out the pocket flares nice. Thanks guys.
That tall of a tire is going to be close. If you have a +18 offset that helps, but by the time you air that tire up it will be all of 34.5 inches. That is tight for stock height in my opinion.
BS is 5.71". Im not so much worried about the tire size the 285/75/17s i was runnin were 34.50x11.50 and they didnt rub but a lil at full lock. So i already have pinned the fenders back.
I believe 5.71" backspace is the equivalent to a +18 offset. If you have the fenders pinned and are confident that tire height won't be an issue those wheels should be fine. You won't get the same look as a -12 offset though. That's a big difference in how far the wheel sticks out of the fender and how deep the dish is on the wheel.
These are 275/55r20 on 20x9 monsters.
I'm running the exact rim setup. You'll be fine, I'm running 35's with a level and track bar and it barely rubs the plastic on the front at full lock.
Thanks for all the input guys! 2011Cummins Do u have shot of ur truck lookin down the side from the front. So I can see how far they stick out? Man I love the single cab short bed that is [email protected]$$!!!!!
I'll try to get you pic tomorrow. I think it maybe 1.5" or so. Thanks.
Discussion Starter · #10 ·
Thanks I really appreciate it!
Discussion Starter · #12 ·
Man I searched high an low. My younger bro works as mech. He does a ton of dealin with tires an rims. An between the two of us, 3 ambush was all we could find. So Im gonna settle for the monsters. I got to thinkin what if I find 4 an then screw one up. Id just be SOL! Just cant figure out if I want the 20x9 or 20x10. I want em to stick out a lil. So they will look right with my pocket flares. I always have a hard time makin my mind up.
1 - 13 of 13 Posts
