1 - 20 of 60 Posts
What pressure do you all run in your stock transforce tires? Dealer had them at 90 (max says 80.) seems like 50-60 would be a vastly improved ride quality
I dropped them to 65 in front, 60 in back - huge improvement already. Might try 50/55
What pressure is recommended on the door jam sticker?
What's recommended when at full load.
Anything less than that should be lower pressures, as easily found in a tire load chart.
Been running 65psi. They heat to 71 when warm.
If you go much below that the tire pressure sensors sometimes go off like you are having a flat.
This is what I'm doing - 60 in back, 65 Inc won't. Drives much better than 90!
You don't know what you're missing.
Ride quality and handling vs. an irritating light on the dash. Your choice.
Reactions: Jimmy N.
I run about 60 front, 50 rear year-round, towing or empty. That's sufficient per scale weights and load and inflation table. Good ride, wear and traction.
Discussion Starter #16
Thank you! I think I'll try this. I'm at 60/65 right now and it's pretty good but will try yours
I should add that's sufficient for towing our TT, family of 4, box full of junk for a summer camping trip. If you carry much more in the box or towing a 5th wheel/gooseneck you'd likely need more in the rear at least.
80psi would be overinflated, so negligible:
Or do your own search:
I think there are enough variables with the Cummins to make extrapolating some of that data difficult... Even inaccurrate.
I have 19.7 with psi of 80 over 3k miles.
I'll drop it down and see what happens.
I keep good records. This will put me into winter diesel timeframe unfortunately...
Sent from my SM-N975U using Tapatalk
1 - 20 of 60 Posts
