So im looking at picking up a 99 cummins but there is one tiny problem...
It has a cracked block but it still runs now my question is is there anyway to make a temporary fix to it till i have enough money to get a replacement engine or block, or is it just better to swap it asap
Now that your excitement has died down I will bust your bubble. No procedure has proved reliable. The effort involved is a lot. Your best bet is keeping it full of water until can find a replacement. Leave radiator cap loose if needed. Not much hope if really bad leak.
thanks alot but i just found out that the 98 12 valve i was looking at is still for sale soooo i might just hop on that cause it will last me better over all and its less then the 99 thanks alot for the info though
