What kind of timing would you guys suggest on one of these trucks pushing around 600hp and 4k-5k RPM? Also, assuming that it is running stock pistons.
Thanks,
Sean
if your timing with plunger lift then id try around 25*, that should get you around 22-23* depending on the size of the lines, the injectors and dvs. you may even get more out of it.
