I dont quite understand the timing adjustments that can be done with the SMARTY for example. Is it bad to run the timing setting on 4 with stock injectors?? Please enlighten me.
There is a long post discussing this very topic, type in smarty timing in the search box it should help ya.
Ahh yes there is! Thank you very much. But there were a lot of guys askin if running the timing setting on 4 would do any type of engine damage but they were not answered.
I think #1 was the lowest amount of timing then #4 then #3 and the highest was #2. So 4 should be fine
i asked yesterday which setting were better for a stock truck,,, second reply was BOB WAGNER and his answer was the ODDS. the others only fuel which creates higher egt's. not sure if i like the rattle but it does run a little smoother
This wrong for the S67 ans S67ME Smarty, which is what 6.7L Use.
What he said was for a 5.9L.:thumbsup:
