1 - 20 of 53 Posts
What are you using for a trans in the project?
Allison most likely. Investigating my options for adapting it to the 5.9. I believe I have the stock auto out of the wrecked truck sold and I have a line on an Allison
A Duramax Allison or one from a heavy truck? I used to work on Ottawa Yard trucks and they put Allison 1000's behind the 24v's.
Reactions: 93oneton
Just the transy friend, it will still have an inline 6 with a Spinny injection pump:grin2:
I knew what you meant.....just an option for me to state my thoughts on a duramax....:D ;)
Reactions: 93oneton
If your wanting to go manual a zf6 is a really good trans and they can be had cheaper than the others, but then you'll have to have a adapter and flywheel expense though.
If you can find me /2wd 6 speed I'd be all over it!!
2wd and 4wd g56 are pretty much identical, the only difference is the 2wd has a flange bolted to the back to house the rear seal and the slip yoke for the driveline rides on the same shaft.... just food for thought. A 6 speed mansmission would certainly be cooler than the Allison but all in all your probably better off going auto.
Damn you guys lol. Now I don't know what to do hahahaha
That's what happens when you go and post something and ask us to help. Is there anything else you need help with?
The 47 and 48re's are good transmissions and the Standalone controller I used in my Blazer made the install easy and fun to drive.
Except he’s the dare to be different variety ;) 93oneton another thing to think about is ground clearance.... the g56 is HUGE!!!!! I’ve read that it may drag ground on a 2wd first gen and with how long your wheelbase is that doesn’t help.
I just had to throw in another option in just to make it more difficult.
1 - 20 of 53 Posts
