Hi every one. I'm a diesel mechanic for the last 22 years
I've owned this 02 dodge auto for four years and it had been trouble free till now.It has 220000km on it and the throttle pedal goes dead for second every once in a while. it gets worse when its hotter.
I got the codes read at the dealer and he came up with code p0215 injection pump timing failure and lowfuel pressure from transfer pump. the service tech said that the transfer pump pressure is too low it starves the injection pump for fuel and that takes out the injection pump. He suggested to change to the fuel tank mounted kit for $568.
Is this kit worth the money?
Or should I mount a Carter 4600 in the frame or buy the FASS kit?
How much is the FASS kit?
This truck has a Edge ez module and has lots of power for what I do. Every thing else is stock.
