The adjustable throttle shaft on the front of the motor (one with ball joints) is REALLY sloppy and needs replacement. The shaft almost falls off the ball. 2 questions. Is the adjuster rod 1/4" ? Also can an aftermarket throttle end such as sold by Summit or Mr. Gasket be used to replace both ends of the shaft (part # mrg 3810g).
The original parts are no longer available through DODGE and there are none to be had according to my local DODGE dealer. These were a recall back ??? but looks as if mine was never done. Truck is a 91.
Thanx
Charlie
Thanx
Charlie
