I have an 03 3500, 6 spd truck that I just put a motor in. Motor and ECM are from an 03 automatic. It runs and drives great, until you go full throttle. When you do, the truck falls on it's face and goes to idle for about 5 seconds. Then, throttle response comes back. I'm wondering if it is just an APPS problem, or is the ECM cutting fuel until it sees a successful downshift from the auto trans( that isn't there) the pedal sensor is the style that is mounted under the drivers side battery. Thanks in advance any ideas are appreciated
