Two weeks ago truck dies in driveway, towed to shop and replaced lift pump on engine and pump in tank. Ran good for two days then wont start until third attempt then fired up runs great until next start. Must cycle start and wind about ten seconds three times. thanks for any help.
Sounds like you have a leak somewhere.
FYI the in tank pump is the lift pump, the one on the engine is CP3. If you have a lift pump mounted on the fuel filter housing, there is no lift pump in the tank.
Need to confirm if the pump was moved to the tank. If it was, there is an added harness and relay that can have issues.
Trying to learn
Yeah, your post doesn't make much sense, figure out what was done for sure and let us know.
Reactions: rghavana
a few years ago the truck quit, they said the lift pump on engine was bad so changed it, that fixed the problem it was a lifetime so they changed it this time, didn't help, changed the pump it tank that fixed the problem. this was a week ago. now this problem of having to wind engine three times before it will start
Stock truck, No pump in tank just fuel level sender.
Verify lift pump working ?
Check for codes ?
If no codes good lift pump supply, injectors/CP3 are suspect , check rail pressure when trying to start.
Trying to learn
There is nor ever was a lift pump on the engine with a 2003 truck.
On the engine is a high-pressure pump called a CP-3.
2003 came stock with lift pump (LP) on the back of the fuel filter housing and a fuel level sender in the tank.
Some trucks, due to the LP being poor design at the time were retrofitted with a combo in-tank LP/sender unit.
Hope the clears things up for you.
