I have an 04 Cummins I rebuilt after crank went out drivers side of block. I seem to be missing what goes in the threaded hole behind the ecm. Here is a pic. Any help would be appreciated. It’s right behind ecm wiring harness and above the crankcase vent
Some of the threaded holes in the block are unused
Ok just checking seems to be smaller then the other holes that have plugs in them. I cannot compare the old block as that is where the rod went through. Does any one know the size plug or should I call the stealership they have not been any help with anything in the rebuild process
I know nothing.🙄
I’ve looked online and I see there an m10x1.0 9.5mm long that goes in that area. Do you think that hole is 10mm?
If so, p/n is 5003614AA
Reactions: tryNto
Looks like my 2004.5 had a plug in it.
930171
