looking into ordering gates barricade fuel lines for my truck since i cant use the 1st gen fuel lines to the 2nd gen lift pump... anybody have any experience?
thanks.
Super Moderator
Why can't you use the 1st Gens fuel lines?
they dont have the same ends to connect the 2nd gen motor has stainless with rubber line on it, wich i think was not factory. there for i need rubber lines and have heard alot of god about these lines, just wondered if anyone has had any personal experience with them.
Super Moderator
You should be able to put a barbed fitting on the LP and then slip a piece of rubber fuel line over the existing fuel line if it's plastic and double clamp it.
it is a barbed fitting that why im running rubber line from the tank to the lift pump.
