Yeah, I've seen your setup several times. I know you didn't have to run lines, but you must work really fast to do all that work in an hour!! Although I wouldn't doubt having a long bed may have made things easier. It's cramped under mine.
So you notched a rectangular section as opposed to my V-nothces?
Tommy
Well I kind of cheated... :lol3: Stock pump and vulcan big line...
The new setup... If you look close you can see the previous mounting holes... Notice the fuel line is dirty... Yeah I re-used a lot of hose...
I already had a Vulcan Big Line Kit in the truck so mounting the pump what 4 allen screws and 3 bolts... Run the wire the same place the old Vulcan lead was. Then install the return line... I pull 2 clamp and cut the hose and installed the fitting... I used my old wiring as a snake to a pull the new through using the old. spent a hour doing this...
But skipped the draw straw because I had a trip to make up north and figure if the stock sender would hold up then I wouldn't bother... But the stock sender kept pulling the fuel pressure down...
So next avalable time I installed the draw straw. I can sit under the truck and grab the sender ring and loosen it. Left it attach to the lines and electrical. Pull both band (2 nuts) carrier bearing (2 bolt), slid the tank out on the floor (empty of course). Drill 1 hole and trimmed the tube. Notch the end and re-assembeld in about a hour...
I used all air tools so wrench time is reduced...:w:
So roughly 2 hour total but the draw straw was really easy to do...
But if you where to start from ground up yeah... It would be a long project...
