Some friends came by yesterday to help me lift the bed off the truck so I could figure out how to address the draw straw issue. Basically, I had two options.
1. Plug the existing hole near the rear of the tank and put a new hole near the original fuel pick-up area.
2. Extend the length of the straw and keep it where it was.
Here you can see what I had to work with:
I elected to go with option 2. I picked up a union and extended the straw so that it was just barely off the bottom of the tank. Then I cut 3 V-notches into the straw. Things went smoothly and it fired up first try. So I took it for a test drivw. FYI, I had about 5/8th of a tank of fuel.
At the first stop I made, my Edge beeped at me again for low fuel pressure. UGH!! :CRY: So even though the straw is damn near on the bottom of the tank it still sloshes around enough to starve.....even on low speed stops!
I realize my mounting location is farther rearward than most, but if you look at the pic above you'll see I really only have two places to use: the flat spot I used or the somewhat crowded area near the original pick-up and sending unit. A short bed setup doesn't leave many options. So I guess I'll have to do it all again and this time I'm thinking I'm going to try to drill straight into the top of the pick-up assembly and hopefully get the straw into that baffle.
I tell you what. I wish Pure Flow would offer an insert to replace the OEM pick-up/sending unit that would have a fitting for the hose. I'd have bought that in a heartbeat.
Tommy
