1 - 10 of 10 Posts
aright so i thought i had an hx 35, i just looked and have a whc1, can i still use this for a twin with an ht3b or should i get an hx 35 or 40? and will these match up so i can use it as a larger single until i can afford twins?
Discussion Starter #2
anybody got any suggestions, wondering if its worth the time and money to rebuild this one or just buy an hx40 and make twins with that later.
well if you where really going to buy a new turbo go buy a really nice single like a phat shaft or something of the sort and save up for a big bottom turbo.
yea, some of the very early 94s didnt get the 'newer' hx35.
Surely you can still use the W on some twins but i wouldnt expect alot out of it, i would be looking for an hx40 if you plan on decent power
Pretty much the same beast but IIRC the hx flows slightly more than the WH1C
I believe the wh1c can actually take a bigger wheel if you make a hybrid. I have a hard time thinking you will notice a difference with the wh1c vs an hx in twins. Both 94s motors I have came with the wh1c. Use the wh1c, build your twins, upgrade later to a S300, IMHO.
Discussion Starter #8
aright, thanx, i guess ill order a rebuild kit for this w then, and use it, unless i can find a cheap hx 40 layin around
my truck has a build date of 11/94 and it came with a wh1c, so, you will find em on early 95's also
1 - 10 of 10 Posts
