Hey y'all, I haven't posted in an aeon, all stuff I could figure out. Here's a good one tho. Piles of white smoke (unburnt fuel) out the exhaust, dead number 1 cylinder on a 95 dodge ram, CTD,12v p-pump manual that fires up instantly and runs great. On 5 cylinders.
Cranking sound is even on all 6, Compression is fine, cyls 1,2,3 all 280psi at 5 degrees F, 10v @ cranking. Only checked 3 because only #1 is acting up. This is a replacement engine from an RV- only about 70k on it now.
As of now, new P pump from Pensacola Diesel, new 7x.011 injectors (second set) from DAP, fuel feed pressure is 40psi at the IP from a raptor pump, valves set proper, everything I check specs out as correct.
I'd waited 2.5 years to put my new p pump in, the guys @ pensacola said it'd be fine. This was a warranty replacement p pump. Same thing with the first p pump from Pensacola. Dead number 1.
Lots of fuel spray out the lines, cylinder 1 is wet (drenched) in fuel in the bore.
Engine ran great 1 month ago. Lift pump failed, drove 7 miles home with no lift pump (how?), changed lift pump and the old p pump didn't behave right. Ran ok, started really hard, misses at high revs... Time to swap in the new p-pump I thought.
Injectors were already newish 7x.011's, but bought a new set to test with a new IP. No change. Swap injectors between cylinders- still number 1 dead...
Been wrenching for many years, fix alot of vehicles for other folks, my own is leaving me scratching my head. Needless to say, it's my work truck, kinda need it running.
I called pensacola after a day or 2 of trying to figure out a dead number 1 cylinder 3 years ago. They agreed, must be a IP problem. Sent them the p pump back for warranty and they accused me of messing with it. The barrel had moved and jammed the rack wide open. I'm glad the truck wouldn't restart at that point. That could only have been their oops in the rebuild process.
So, at that point, I reinstalled my old p pump and been running it til a few weeks ago. Ran great, but old and weak. (Old RV p-pump)
Short story long...WTF? Another bunk p-pump from Pensacola? Anyone heard or experienced anything negative about their work? I think I need to pull the pump, take it to the city and have someone else go thru it...
Any thoughts or ideas are welcome and appreciated. Cheers all, happy holidays!
