Ya you can as long as your u-joint angles cancel out within one degree every angle taken from tranny angle all the way back to the tilt of your rear diff. plus all calculations inbetweenThe 2pc is not used for angles, you can't just stick a 2 pc in a truck and run different angles because you want to have clearance...oh you can, but it won't be enjoyable anywhere else other then off-road, and on road it won't be cheap without a cv, or possibly 2 cv's.
