How many miles does it have? What transmission? 4 wheel drive or 2 wheel drive.
Dodge transmissions are about the worst in terms of durability relative to the other 2 American truck manufacturers. Determine if the fluid is in good shape.
The suspension in these trucks seem to be severely underdesigned. Especially on 4 wheel drives. Upgraded parts are available but it'll cost ya.
Has the lift pump been replaced? On a 2003, the stock lift pump is attached to the back of the fuel filter bowl, and is a poor and unreliable design.
If the owner will let you, take the cap off the fuel filter bowl (a large-ish adjustable wrench will get it off without much problem in lieu of a socket for the large hex on the cap) and take a look at the fuel filter. It should be white or light tan. If it's dark brown or black, the owner hasn't kept up on maintenance.
Take the oil fill cap out of the valve cover while it's running when it's warmed up. Slight wisps of white vapor is fine, chugging like a locomotive is not.
Basically, these trucks are fine if they're taken care of. If they're neglected, it'll cost ya.
