1 - 19 of 19 Posts
Has anyone tried the ats thermal bypass? I haul Rvs for a living and have been looking for ways to take care of my tranny. This is my first ram and it dont have the aisin so I'm kinda worried about it. Havent heard great things about the 68rfe so I thought I'd ask around and get some ideas.
The 68RFE is a good transmission. Don't re engineer, the stuff works.
From what I've read it isnt that the factory valve goes bad its that it keeps fluid from circulating to the trans cooler until it reaches a certain temp and the thermal bypass lets it constantly circulate. What im unsure about is wether it's worth it or if it even matters
I wouldn’t overthink it. Plenty of high mileage guys on here with an un-modified 68. Leave the power stock and haul away. It’s designed to operate up to the tow rating on a consistent basis.
The vast vast majority of owners never have an issue with their transmissions.
Now start modding things and all bets are off, you may last forever you may not—especially if you add power through tuning.
Discussion Starter #8
Well I'll be deleting it after the warranty is up and I know some power is added with a delete tune even though I'm not looking for more power. I'm deleting for mpg and not having to deal with this stupid egr and def its gave nothing but problems and only has 50k.
Bought the rev max one. Get the ats one, i think it is made better but the temps on my trans have dropped 10-20 degrees. Much cooler while towing my TT at 70.
Sent from my Nokia 7.1 using Tapatalk
How was the install? Any tips? Any unexpected pain in the butts? How long did it take?
Sent from my Pixel 3a XL using Tapatalk
The rev max was a pain to install because the end where the threaded lines from the trans attach are not quite right. They are offset where the original has them even with each other. The ats looks to more parallel the stock unit. Because of the lines, it took forever with me under the truck and a broken jack. The fittings need stubby wrenches to loosen and tighten because of the space. And i lost about 3 qts of fluid during the process. Should have put the truck on ramps but you live and learn.
Would have been a normal 1 beer job except for the way the lines fit.
That thermostat is there to get the transmission and fluid hotter so there is less drag from thick fluid. I took the thermostat cartridge out of mine and made a plug to drive into the center of the block so that flow is always to the cooler and my trans ran 20° Cooler. I’ll take a cooler transmission over hotter any day. I’ve known a lot of transmission builders who told me they never heard of overcooling an automatic. Do a search on automatic transmissions and heat and you’ll see how as heat goes up life of the transmission goes down. My truck came with the max tow welded plate exchanger which is basically another fluid heater because it supposedly cools the fluid with engine water. I did away with that exchanger and replaced it with a fan powered remote Derale cooler and now my transmission runs 150° towing. Craig
Do a search and read about how transmissions life goes down as temperature goes up. That thermostat block wasn’t put there to make the transmission last longer. Craig
Sorry for the duplicate post but my phone was not showing me my earlier post.
Automanfactures try their best to save even a fraction of a penny.
Knowing this, why would RAM install this? When just using straight lines, it would be much cheaper.
As BFD brought up, its to help the oil reach a set operating temperature. However, we all know that the cooler an Automatic the better. So, why would RAM want it at a set temperature?
Hotter oil flows better and "sucks" less power than cold oil. Also, you want the transmission to get hot enough to evaporate any water in the oil. Finally you have thermal heat transfer. The hot oil needs to remain in the cooler long enough for the air to extract the heat. Move the fluid too fast, and not all the heat will be removed. You may not notice this when operating under the limits of the cooler or not making heat in the transmission. However, under extreme conditions, the thermostat based system may cool better.
Finally, the transmission shifts differently based on temperature. When cold, it holds the lower gears longer. If you live in a cold climate it will take much longer for trans to reach this set temperature, affecting your MPG.
As I live just north of actual HELL, I'll delete my transmission thermostat.
I'm a firm believer that a cool transmision is a happy transmission.
Yep, fluid cooling is forgiving. If the flow is faster there is less heat exchange but the fluid passes through more often. The net affect isn't as drastic as the flow changes. No exchanger is 100%... You will never have 0* approach. Keeping exchangers clean is also critical. Approach temp goes up when the surfaces are dirty. That might be why some guys get more benefit from the tstat bypass... The air cooler is more plugged with bugs and dirt than the next guys cooler.
An extra bonus from cooler temp is firmer shifting. A Protect 68 or VB WAS going to be my next mod but I wouldn't want it shifting any harder than it does now. It's on the borderline of slamming, when in tow/haul. I think it's just right but that wasn't planned... I'd rather be "lucky" than "good", any day! Craig
1 - 19 of 19 Posts
