1 - 20 of 22 Posts
I've been lurking and trying to do my research for a few months now. I've been wanting to put a Cummins in my 64 Dodge Crewcab. I've been searching for a 12 valve, but stumbled across a lightly rolled 99 24 valve 4 wheel drive 5 speed truck. To good of a deal so I picked it up. I will probably be asking for a lot of help, but I will try to do as much research as I can first so I don't repeat to many previous questions...
I would like to know how much you picked up that lightly rolled truck for! Looks like a Perfect donor truck!
Good Luck on the conversion!
Merrick
id like to have the transmission i wish i could find a truck like that around here
Yeah, Youd be crazy to pass that up!!
Can't wait to see how this turns out!! Will You be lifting it at all?
:popcorn::popcorn::popcorn::popcorn::popcorn:
Probably not @ first, but we will see what happens..Anybody know what the wheelbase is of this truck? I didn't get a chance to measure it...
damnnnn..is the dodnor truck driveable?
TECH SPECIALIST
please don't kill me......$1000
WOW YOU THIEF! That is a steal!!
Good luck on the conversion. That will be really nice when it's done.
Great Price:thumbsup Good luck with the conversion!!!
Discussion Starter #11
yes it drives. the kid that rolled it drove it home. We also drove it out of the yard before it got pulled onto the flatbed:thumbsup
Man you are a theif. Its hard enough to find a engine that need to be rebuilt for that price. There no any of us could have turned that down.
Yeah $1000 is the best deal I've ever seen on a wrecked truck, the front end alone is worth more than that. I bet you could sell it today for $4000-5000 easy.
If the frame on the 99 is good, why not just put the 64 body on top of it, then you'd have a modern drivetrain on a classic body. Either way sell off what's left of the 99 and you'll get your money back for sure.
Oh, some of those 99 Cummins engines had what they called a 53-block, which was prone to cracking on the right side water jacket. Check yours before you do the swap. Good luck. . . :D
Discussion Starter #14
I do plan on putting the body of the 64 on the newer frame. Might have to get a long bed and cut it down because the wheelbases are a little different..is the 53 block number cast onto the block? if so, where is it located?
I have a wiring schematic
If you need a copy off the wiring diagram I can email it to you. That will be a pretty easy conversion. I did a 78 ramcharger and the only problem I had was finding a Charge Air Cooler that would clear every thing good luck and if you have any questions please ask awy
Discussion Starter #18
My wife threw the idea into my head of putting my panel truck on the frame..It would take a lot of shortening and it's probably to wide. what do you guys think? just thought I would throw it out there:thumbsup
1 - 20 of 22 Posts
