These are my new front brake rotors and pads from The Brake Man. They are made in USA, by Americans, in California. Cost is slightly higher than local auto parts store "premium brakes", but less than OEM cost from dealer.
I already had upgraded front brakes from Raybestos (Rotors) and Pads from PFC, and braking was good.
I put these on, and I thought I was going to be launched through the front window with how well they grab and stop the truck, I had to gained a 30% increase in brake power at least.
I got the rear ones also, but have not installed yet since putting them on requires taking apart the rear axles, etc.. So I should gain even more once those are installed.
If you go this route, you need to get both the pads and rotors as they are designed and treated to work together.
Highly recommend them
