I heard about this engine and considered the possibility of spinning it to 6300rpm. Anyone here familiar with this engine?
I agree, but IMHO this will change. Looking at the R2.8 as a retrofit kit, the torque is too high for too many existing auto drivetrains. Better to sacrifice some torque down low and bend the power curve up. The cutoff is around 450ft/lb for most of the market but the lower you keep the torque, the more cars are suitable for this retrofit. Remember, we're pulling <2 tons most of the time in a passenger vehicle. The appeal here is the use of a diesel engine. If someone had the wherewithal to manufacture diesel heads for existing gas short blocks, that could also be a route to what I feel is an untapped market. An ideal engine would make 280ft/lbs from 2500-5500 and keep the HP constant to redline from there. With modern methods of controlling fuel intake and boost, this seems plausible if not yet affordable.MoparProud said:There is an extremely small performance market for the 2.8 at this point.
