1 - 1 of 1 Posts
07 Feb 2014 Marysville, WA - Terminator Engineering, located in Modesto California has agreed to sponsor the
right lane at the 2014 season opening Spring Diesel Nationals at the famed Auto Club Famoso Raceway on March 22nd, 2014.
About Terminator Engineering
The TERMINATOR High Pressure Oil System DOUBLES the capacity of the 7.3 factory high pressure oil pump, ensuring
adequate oil pressure and volume to support all of your power needs. Because two pumps can deliver more oil faster and
maintain the desired pressure without drop-off, upgrading to a TERMINATOR will improve performance at all engine speeds.
Not only will you notice improved throttle response and stronger mid-range, but the typical power drop-off in the upper
RPM range will be gone too! Whether you're towing or racing, your engines performance will benefit from running a
TERMINATOR system!
This TERMINATOR HPOS2 kit comes with 2 new (remanufactured) high pressure oil pumps, the Terminator Remote IPR and all
the necessary hardware to complete the installation. With the exception of installing your current IPR, the HPOS2 comes
ready to be bolted in place of your stock pump. Simply install your IPR (or a new one if you wish) and you can start
enjoying the benefits of "Big Oil".
CONTACT INFO:
5018 Paradise Road
Modesto, CA 95358
Email - [email protected] or visit the website at
www.terminatorengineering.com.
1 - 1 of 1 Posts
