1998 Dodge Cummins 4x4 manual 5 speed 4 door long bed 260,000 miles
I’m replacing the water pump, and used a very small ratchet with a cheater bar.
Now I’m installing the pump and the tensioner has me confused
IT DOESNT SEEM LIKE ITS SITTING IN THE CORRECT SPOT now to put my ratchet back in the square hole used for taking the tension off (DOES THE ASSEMBLY NEED TO BE ROTATED BACK AROUND COUNTER CLOCKWISE)
to get back into proper position ??
to therefore put the belt back into its functioning place where it holds the belts tension
Please help, I took this deal on at night with poor lighting, and didn’t take any picture to use as a reference.
***Love my Cummins, it’s best to not fall behind on maintenance once the oil starts leaking 🤬 but that’s any motor
