My truck is stoping all on its own when I get out of boost. Its also failing the tea kettle test. The oil filler cap rattles and pops right off.
I am pulling 26mm of vaccume, the AC and heat work fine. No leaks where the pump connects to the power steering pump. Turbo is tight with minimal oil on intake side. Pyro reads fine always driven between 650 and 875 on the pyro. 77Kk miles on the OD. Im not the origional owner though.
I think I am going to have to replace the motor. That much pressure is sure to have messed up everything of value in the engine including the block.
Any ideas of additional tests or places to start looking for a replacement?
Thanks as always.
Thanks as always.
