Hi everyone I have a 2001 Cummins and i am getting a surge in the tranny at 45-55MPH. I have read that this is caused by AC sin waves from the alternator. the thing about my problem is that it only happens when i have the heat on full blast. if i put it on level 2 its fine no issues at all once i turn the heat all the way up it surges.
I am going to load test the batteries and clean the terminals my big question is do i need to change the alternator? If i clean the terminals and grounds and it goes away will there still be a risk of the ac sin waves hurting my ECM? is there anyway to protect my ECM dont want to destroy a 2000$ ECM. I tried to find Mopars tutorial on ac sin wave testing but i cannot seem to find it if anyone knows where i can find that i would greatly appreciate it.
With the truck running at idle, check at the B+ terminal on the back of the alternator with a digital volt meter on a 2VAC or lower scale. Anything more than.10 (1/10th) volts AC indicates a bad alternator. It can fry the ECM, PCM & VP44 computer.
Ed
Mopar1973Man has the writeup on alternator testing. If you fix with grounds and problem goes away, you have fixed it's particular issue. Nufffff said..
I figured out years ago that sometimes increased load of the fan or power windows, etc , will exacerbate he AC noise coming from the alternator causing the lock up issue.
Reactions: Mopar1973Man
· Mopar1973Man.Com
One thing, Diodes are not the only parts to go bad in the alt causing the ac problem. Mine was a bad rotor in it. Can be rectifier too.
