1 - 3 of 3 Posts
Just added a tc lockup switch to my truck. i did it myself. the problem is i'll turn it on, and it will only choose when it works, like every once in a while. you can definately tell when it does work. all connections are good, and the switch is good, what could be the problem?
Banned
good ground? which wire did you use? your t/c might be going out or there is a loose connection on the transmission. Did you jumper your transmission relay in the under hood fuse box?
did you use a 33ohm resistor and jump the Relay?
1 - 3 of 3 Posts
