1 - 3 of 3 Posts
I recently got delivery of my fuel pressure gauge, along with a tapped banjo bolt and needle valve. However, I can't seem to locate a a port that will accept a a tapped banjo bolt. Does anyone have a pic that shows where such a port may be located? As close to the injection pump would be best. Also what size of copper or nylon line do I need. Thank-You
the banjo bolt is on the vp44 follow the line from the bottom of the fuel filter it also has a Schroeder valve in it . be carefully not to over tighten the banjo bolt i like to use a 18" grease gun hose in the banjo bolt get a oil sending gauge kit get the copper line one it will have all of the fittings you need with it , depending on gauge and noise you may want to add a snubber at hose to copper tubing connection if you decide to build the snubber rather than buy contact me and will send how for about two dollars worth of parts
Hi Carl! Would you have a picture of your setup?
Thanks
TC, a newbie.
1 - 3 of 3 Posts
