1 - 4 of 4 Posts
Ok.. so drivin home from work tonight...tach went to zero..CEL came on...but that's it...truck didn't skip a beat...tach came back after about 10 sec. but CEL stayed on...I know the CEL is a latched fault..and will probably clear after I start up a couple of times..Got code P1693...which I know is either a CSPS or the pal code that comes along with the CEL..My question is...how often does a CSPS go bad? I just replaced it a year ago... and have had no problems until tonight. Do they have a high fail rate once replaced or is my ECU going bad? HELP!! :S:
Discussion Starter · #2 ·
Oh...and I didn't have any automation turned up either...just stock mode...
Well had a buddy look up the codes... looks like I'm changing another CSPS...ugh!!!
hey, if you need any help let me know and you can swing back by this weekend and we can swap it out for you. :thumbsup: My wife will be around to watch the little one so maybe we can have a few cold ones! :grd:
1 - 4 of 4 Posts
