I have been looking at what has been used .One uses a gear that looks to be the same dia as the balancer bolted to the balancer it has 54 teeth,one had just 4 teeth on was just using the stock cut outs in the balancer. With out pulling the gear on my 7.3 I do not know how many teeth it has but they look to be about the same size as the 5.9 and the gear dia must be close to the same from measuring the out side of the housing the 5.9 has 72 teeth.The pump turns at 1/4 the speed that the crank does right? So if the sensor is counting teeth that would not work or am I missing something the more I think about this the more I confuse my self .I would like to put the sensor on the 5.9 IP gear like it is on the Ford.
