1 - 4 of 4 Posts
My 91.5 came with banks Tach and it worked fine up until about a month ago. Now it just moves a tiny bit. I have moved the sensor on the balancer closer and further with no results, all the wires seem to be intact. Is there any way to check the Tach or sensor? Do I just get a new sensor or Tach or both?
Any suggestions would be appreciated
Thanks
Joe
this aint much help but if you cant find out what the problem is and need a new tach check out autometer's mini diesel tach its sweet
Have you asked Banks? They'd probably know if there was any common problems with those gauges.
Thanks for the replies.
I have seen the Tiny Tach, but I like the look of a dial better.
And I had no luck with banks either.
Is there anyone who knows a way to check a Tach or sensor.
Thanks again
Joe
1 - 4 of 4 Posts
