1 - 9 of 9 Posts
my 5th gear has started to grind for just a second before falling into gear if you try and shift above 1500RPM. if i let it drop below 1500 or so it falls right in. wondern if its the syncro. anybody else had this problem
Discussion Starter #2
nobodys anything like this?
hydraulic lifter crew
it will always fall into gear if you float the gears when shifting.. sounds like a syncro is headed out the door , or maybe your clutch is going out and not disengaging itself all the way.? not sure if that would affect all gears, or just a certain one.
yea it only does it in 5th all others shift fine
Tech Specialist
Ive been hearing alot of 'catchyness' with 5th gear on the G56's. . .some have done it since day one. . .others have gotten better with age, but still have that slight grind.
Mine has a slight catch going onto 5th since new. Never any grind, but it's like you can feel the syncro working, but I find if I rev a little higher like 2300 -2400 before shifting it is better.
my 5th has always been the hardest to shift into but the grinding just started. its got 29000mi. on it
I just noticed mine doing that and...
I just noticed mine doing the 5th gear noise and I now have 20G's on the odo. I also notice that sometimes when I am coming to a stop and down shift that I hear a very fast wierd chatter noise. That noise doesn't happen all the time though. I am sure its not the clutch, its a different chatter, it seems like I can feel it through the handshaker.
Eddy:peelout
My 5th gear has always had gear noise when shifting.. All others make no noise.. Currently 26,000mi
1 - 9 of 9 Posts
