I just bought a new set of adjustable sway bar end links and was just wondering how to set them up as far as length? They adjust from 0-6'' lift just wondering if there is any trick to setting them up.:thumbsup:
Thanks Mike
I ordered mine from Top Gunz Custom,
818
Basically when the truck is sitting on the ground. You want the ends of the sway bar to be level to the ground. Make sure they suspension is loaded.
Thanks for the info
I also got mine at TOP GUN CUSTOMZ
Yup those are the ones I got. I had to adjust mine all the way up to get the sway bar level with the ground. I have a problem when I hit a bumb that the link hits the spring, I tried to adjust the links but no mater how I adjust them they still hit the spring.
