1 - 4 of 4 Posts
Has anyone heard of disconnecting the swaybar end links when putting the truck on a lift? i bought a tuff country add a leaf and it said to do that. Well a week before i put the leafs in i changed my oil and put it on a lift. Now my truck handles like SH!T. Not sure if when you lift it and the axle comes down, that it puts strain on the steering bars and bends them a bit. not sure, what do you fellas think???:confused013:
I had the same problem after adding a 2 inch leveling kit. I ordered from summit new end links 2 to 3 inches longer for a leveling kit also much better bushings. just drop swaybar remove old end links readjust swaybar and bolter up & good to go. I also added duel stabalizers to help with steering and dreaded death wobble. problem solved.
I'll have to look in summit. not to much cash were they?
end links
I believe i paid around 80-90 bucks. I belive the name is maxxis end links they have several lengths just look up what size lift you have on your truck and you will see the correct length end links to buy.
1 - 4 of 4 Posts
