61 - 64 of 64 Posts
Split your air bags. so each is filled independently. If they are joined right now when one collapses the other over inflates giving you accentuated body roll.
Sean
Discussion Starter #62
Sean
They were separate before i removed them.
I had a set of airbags on a common hose, that’s a horrible setup for sway, but great for articulation. Fixed it with an isolation valve on one side, open the iso valve to fill both bags equally, then close for loaded stability or leave it open for articulation. It had a weird feeling when open, it took a second to transfer air from side to side so the truck would settle in on diagonal loads. Works great, I’m doing the same on my Dodge CTD one of these days.
If you run a larger diameter line between them, there's no delay whatsoever.
61 - 64 of 64 Posts
