what steps should i take to change out my turbo, since last time i changed it i ended up blowing the new one up 1/8th mile down the road.?!?!?!?!?!?!?!:banghead:
um noo def sounds like a bad turbo.....see i took the manifold off with the turbo, put the new turbo on, attached everything else, did a 4 time look over with my dad, started it, idled for about 5 minutes, took off down the road and next thing i know i was pooring white smoke out my exhaust. got back took it off the next day and realized i seperated my exhaust wheel from the shaft, dont know if I did something wrong or what.
used a half inch long handle rachet adapted down to 3/8 and a real long extension from underneath to get the down faceing nuts off. remaved the oil lines and the down pipe took off the upward facing nuts with a long handled wrench. from there i dropped the turbo downand let it rest on the frame. then i came up from the bottom and removed the metal oil drain tube. then i fished the turbo out from the top. then reverse the order to get is back in. i put the drain pipe in then pulled it up to the manifold and hand tightened the upward facing nuts to let it hang thenput everything except the exhaust and intake back on. tightedn every thin up reattached the down pipe and reinstalled the intake. removing the intake battery and battery tray helps make room to get in there better to get it out. it would have been easier going back together to have a second set of hands to help hold the turbo in place to get the nuts started. hope this helps:thumbsup:Yeah im curious how you got the turbo off the mani without taking the whole thing off.
a couple weeks ago enrout to the fire dept i came up to an intersection, let off to clear it got back on it and realized i was rollin white smoke. then a few days ago blew it up. replaced it with a 62/71 and blew it up. im cursed i SWEAR.
I'll have to check and see if my wrench has that spec. :hehe: now when I fill the center of the turbo with oil do I need to fill the tube as well or will the oil pressure flow oil to the line? Sorry for being a high jacker but you've asked the questions I was gonna ask...I've always used the German torque spec... "guedenteit"
