1 - 20 of 23 Posts
I am wanting to swap my 48RE for a G56 trans, my questions is for some of you conversion aces how much is involved with that? Are they the same length trans will the drive shafts fit, computer size what will be needed Ect.... Any help would be appreciated! Thanks Adam
i'll be watching this one for a friend.:popcorn:
Cheaper to just sell the truck and go buy one.
Go for Broke
BBRam has done the swap from a 5 speed to an auto ....he can help you out on that :thumbsup
6spds are hard to find, it took me 5 months of looking to get mine. and i still had to drive 8 hrs to get her.
I have access to a lot of wrecked trucks so finding one should'nt be a problem but I was just wondering how difficult it would be.
Lets see, New ECM, New Tranny, Transfer Case, Rebuild driveline (Drivshafts ext.)
Ok Good info guys thanks I kinda figured that the transfer case would be the same just have to change the tail shaft on the transmission, and a computer reflash with 6sp software.
Discussion Starter · #9 ·
So did you do a swap of trannies or just get a replacement 6sp?
If the G56 is basically the same as the NV5600. You will need.
The basics that you allready know, Trans, Clutch, Flywheel, etc.
Hydro. for the clutch.
The adapter plate on the back of the engine. (Different length from starter to flywheel)
Transfer case, or input for T-case. (6speed has larger output shaft)
Front and Rear drive shafts. (6speed trans is longer)
Clutch pedal and Steering column.
Wiring harness, (Need neutral safety switch)
The PCM was not needed on the 03 with the manual, not sure if 04.5 is the same.
The auto ECM worked with the manual, just no low speed governor.
That's all I can think of off the top of my head, besides it's a PITA.
Dodge | Commins | Forum
i bought it w/ the 6spd...took forever to find one for sale! but thats what i wanted. i friend of mine is possibly thinking about doin it later down the road, he thinks his tranny is starting to go out already...but we'll see.
I want to put an NV4500 in mine but I bet that would be an EVEN BIGGER PITA
Discussion Starter · #13 ·
HAHA so looks like truck might be getting a torque converter and Valve body at least for a while till I gather parts and the nerve to attempt it. Thanks Everyone for you help.
if you're looking for something temporary yet afordable give Wally at FTE a call very knowledgeable dude and he has a pretty good deal out there.
We had 2 year matched trucks, it took us 3 days to do the swap. :thumbsup
Brian where is Gator haven't seen him on here in a while
I believe he is deployed again. I haven't talked with him in a few weeks though.
That being deployed stuff is for the birds!
Its much cheaper to get a fully built auto. A full built auto will out due a handshaker anyday
Discussion Starter · #20 ·
ok so I decided to attempt this again but think I will be going with either the NV4500 or the NV5600 (trying to stay away from the aluminum case on the G56) are the 4500 and the 5600 the same length?
1 - 20 of 23 Posts
