you won't need longer brake lines for that lift anything over 6 and you will . as for the gasser spring's within a yr maybe more you will be replacing them again because the sag will be worse then what you have now . as for drop pitman arm why not spend a little more and do it once n do it Right n go cross over forget the stock dodge junk .trust me that will be the best thing you will Ever do to your truck.
